show stpd ports blocked-ports
show stpd stpd_name ports {port_list} {blocked-ports}
Description
Displays all blocked ports in Spanning Tree.
Syntax Description
stpd_name Specifies an STPD name on the switch.
port_list Specifies one or more ports or slots and ports.
blocked-ports Displays only blocked ports.
Default
N/A
Usage Guidelines
None.
The following example displays the blocked Spanning Tree ports:
show stpd r1 blocked-ports
Port     VLAN
1:1      v123456789012345678901234567890, v1234567890123456789012345678901,
Number of Blocked Ports : 3
This command was first available in ExtremeXOS 15.7.1.
Platform Availability
